Pattern a face?
Pattern a face?
Pattern a face?
Hi Guys,
Been using SWX for a while and am used to being able to pattern a set of faces in a part. Such as a set of holes or slots etc. I know I can pattern a "Feature" but I cant do that AFTER I have derived a part into a new part?
So I just want to be able to pattern the faces of a hole or slot for example.....
Is this simple operation possible?
johnsonshiue
Hi! Inventor does not have the workflow allowing you to replicate faces on a body. But, you can use the following workflow to get the same result.
1) Use Thicken/Offset tool in Modeling environment -> pick the faces you like to replicate -> set output = surface and distance = 0.
Essentially, you create a surface body associative to the faces.
2) Use Pattern command to pattern the offset surface.
3) Use Sculpt command to cut out the solid.
Many thanks!
Let us know how we did on Trustpilot.
Software Test Engineer
