How to model a nautilus shape in Inventor
eucci
Message 1 of 10
eucci
Does anyone know a way to accomplish the Nautilus shape or Fibonacci shell in Inventor?
I've attempted a few ways without success. The Fibonacci geometry is actually a series of progressively larger arcs. This is ok but I'd prefer a more elegant solution that uses a spiral spline to drive the shape.
Any ideas?
Replies (9)
Message 2 of 10
eucci
or like this...
Message 3 of 10
JDMather
What version of Inventor are you running?
Can you attach your attempt here?
Message 4 of 10
eucci
JDM
I'm running 2017
See attached for the 2nd attempt (not as bad as the 1st)
I actually incorporated an idea of yours from a previous post about creating a spiral feature on a sphere 🙂
Message 5 of 10
TheCADWhisperer
Getting curve right might be a challenge.
Message 6 of 10
salariua
You need to use equation curve for that.
https://forums.autodesk.com/t5/inventor-forum/3d-equation-curve-to-create-a-fibonacci-spiral/m-p/575...
Check my attached model..
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
Message 7 of 10
-niels-
@salariua your model was made with 2017, your signature states your using 2015...
(tried to open your model in 2016, in vain)
Good link to the equation curve though. Smiley Wink
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Message 8 of 10
salariua
I apologize, I must catch up on my sleep first and then time to update the signature Smiley Wink
Adrian S.
blog.ads-sol.com
Message 9 of 10
WHolzwarth
Some years ago I've been playing around with these surfaces in Rhino.
Inventor only can do 3D Math curves, but Rhino can do 3D Math surfaces, too.
Derived part of an imported Rhino file is attached (2011 IPT)
Walter Holzwarth
Message 10 of 10
eucci
This is all very helpful!.
Thanks for the input.
I had a couple solutions for the 2d curve already.
The tough part was coming up with a loft/sweep that would match the curve.
I will have to play around with it next week.
Possibly using TheCADWhisperer's sweep along with salariua's equation curve I can get something that matches.
Or, maybe it's just better in rhino, like wh says...
Thanks for all the help
I'll be sure to post back if I come up with a complete solution in Inventor.
