PATH CONSTRAINTS
PATH CONSTRAINTS
PatrickMacMahon
PATH CONSTRAINTS
PatrickMacMahon
Is there a way to constrain an object in an assembly so it is able to exactly follow a non-linear or non-radial path such a spline as shown below and contained in the Assembly files attached ?
Scott_Parker
Some might be able to propose a better way.  But one way would be.
  1. Extrude the path to create a surface in Path Spline IPT 01.  Doesn't matter the distance.
  2. Create an offset surface 100 mm from the surface created in step 1.
  3. In the assembly create a tangent constraint between the body in Ball_Mid:1 and the surface created in step 2.
  4. Create a mate constraint between the center of the sphere and the XZ plane of the path part.
Scott
Scott Parker
Principal Software Engineer
JDMather
There are several different techniques to do this depending on the Design Intent.
This video (and Attached files) demonstrates one technique.
(This could also be done with a continous loop 2D or 3D path.
johnsonshiue
Hi Patrick,
On top of what Scott and JD mentioned, you can also use Transitional constraint. You will need to extrude the curve as a surface. Then create the Transitional constraint between the surface (transitional face) and the object (moving face) moving along the path.
Many thanks!
Software Test Engineer
PatrickMacMahon
Thanks. This is the solution I have been using and was hoping that there
might be a more direct method. Thanks all.
