Inventor Forum
Pass properties from assembly to derive part to IDW drawing
5 REPLIES 5
SofiaGrave4819
546 Views, 5 Replies
Hej to all
I am using inventor 2013, and I have some model and like the word say they are model that i will use as derive parts to machinned or change dependending on the model. then I make the IDW drawing from the derived part.
Most os this models are assemblies.
what i want is to pass the model number to my IDW drawing of the derived, so i can see from which model the part is derived.
could some one help me with this.
Thanks to all
and i appreciate all answers.
Sofia
5 REPLIES 5
Hi Sofia,
thanks for your question.
by model number you probably refer to a Part Number or an Assembly file name. I'm afraid that a derived part doesn't hold any info about this.
Martin Bernat, Autodesk
Yes I refer to a part number or assembly number.
but it's possible to do? by different methods?
You may try to add a custom iProperty (say ModelNo) to the part containing the Model Number - must be entered manually. Then add a New Property in the part list's Column Chooser with the exact name (ModelNo).
Take a look at this document for more info:
http://forums.autodesk.com/autodesk/attachments/autodesk/78/421283/1/Custom%20Parameter%20Formatting...
Our ModelNo could be something like SAPNumber (page 5 & 7).
Hope this helps.
Martin Bernat,
Thanks for the answer
I will try that and see if it works.
At least I already learn something with the paper you sent.
I have tried the white paper, but i can't manage to make it work.
 in the enclose file i have what i intend to do.
appreciate the help so far.
sofia
Technology Administrators
