Is there any way in inventor to address the distance between generated teeth when using gear design facility of the desgin accelerator please?
My cnc machine's tool is 3mm diameter and I have to specify the teeth so that they stand not less than 3mm from each other.
I know I can design gears without using the design accelerator, but that makes life much harder because I'm not a mech. engineer and using design accelerator prevents trivial mistakes I may introduce.
Any help greately appreciated, thank you
