partlist sort / reorder
sorting the partlist does not work out properly with inventor pro 2021 64 bit Win10.
when I want to sort after one manually added column (type=text) it does not sort alphabetical.
also renewing the counter does not work through all levels.
export:
columns A to C (sorted by C) is wrong
columns E to H (sorted by H) is how it should be
any idea which setting I could modify for correct results ?
johnsonshiue
Hi! Could you tell me what the second sort condition is? It is not showing on the exported table. If possible, please share the files here. Forum experts can help take a look.
Many thanks!
Software Test Engineer
Thank you for your response!
The interesting thing is, that the sorting and renewing works fine with the same assambling group in inventor 2020 from a colleague (columns E to H)
Actually it just has been sorted directly in the partlist by column H.
2nd step has been renewing the counter from column E which lead to the exported columns E to H.
When I did the same with inventor 2021 it will always create the same wrong sorting in column E.
Also the counter in column A seems to be fixed. Renewing the counter does not have any further effects, as you can see column A is mixed within one level.
I also tried to import the main settings from inventor 2020, but still with the same result...
johnsonshiue
Hi! Have you installed 2021.1 update?
Many thanks!
Yes it is up to date. No further updates are available
johnsonshiue
Hi! Then I need to see the files. If possible, please share them (zipped) with me directly johnson.shiue@autodesk.com.
Many thanks!
