Inventor Forum
part base view "Diplay Option > Thread Feature" default is off - 2015
3 REPLIES 3
697 Views, 3 Replies
It appears the base view of a part in a drawing will not display threads unless you explicitly turn it on.
  • There are no apparent settings in the template.
    There are no settings in the Application Options.
  • An idw template from 2007 exhibited the same behavior, so it is not something changed in the template. It is now hardcoded that way into the software, my guess.
    Saving a drawing after inserting a view and turning the option on for that view, then removing the view and saving the template does not impact the setting.
    This appears to be a bug, since this is the first of 19 releases of Inventor with this issue, and almost all part drawings should be drawn with thread features visible.
3 REPLIES 3
Curtis_Waguespack
in reply to: Curtis_Waguespack
Thanks Curtis but it looks like the solution is to completely rebuild your template from the idw shipped with 2015.
Bringing a template forward creates the problem, and there is no fix.
QuasiMojo states (rather tongue-in-cheek) : ** And the issue it him at 2013>2014**:
"My 2013 default.idw had threads shown by default, for sure.  I used that template when I moved to 2014, never bothering with modifying the stock template.  When Inventor 'migrated' my old template it seems to have made the executive decision that I should have threads off by default.  I protested, but was unheard.  Opening the 2014 stock template shows threads by default.
Thank you, Autodesk, for providing me with the opportunity to study every change I made to my default template as I completely rebuild my it from scratch."
Curtis it does not appear as though this is resolved - thought you'd like to know. Don't take it the wrong way because I appreciate your link but now we have two posts, a problem that has now manifested for TWO releases, and no apparent good solution <insert sad frowny face>.
johnsonshiue
Hi! I don't think you need to rebuild any template file just for having thread display on by default when placing a base view. Please take a look at the solution in the following discussion.
http://forums.autodesk.com/t5/Inventor-General/Display-option-thread-feature-off-by-default-in-Inven...
Thanks!
Software Test Engineer
