Is it just me, or did the Drawing View Thread Feature option get switch to default OFF, where it used to be on? Did I do something on accident to make this happen? Does anyone know how I can get it back by default?
All views and no threads makes Jack a dull boy
All views and no threads makes Homer something... something...
Not that it's driving me crazy or anything
Solved by mrattray. Go to Solution.
I think you might have it backwards..
I don't remember it being on in previous versions but its checked by default now with 2014 SP1..
Or Obi-Wan Kenobi is doing that Jedi mind trick again..
Your reply gave me a clue. My 2013 default.idw had threads shown by default, for sure. I used that template when I moved to 2014, never bothering with modifying the stock template. When Inventor 'migrated' my old template it seems to have made the executive decision that I should have threads off by default. I protested, but was unheard. Opening the 2014 stock template shows threads by default.
Thank you, Autodesk, for providing me with the opportunity to study every change I made to my default template as I completely rebuild my it from scratch. Not allowing preferences to be configurable is a wise approach to designing technical software. It is a very good use of my time.
2+2=5
Mojo this is hitting me now going from 2014 to 2015. Did you ever stumble across the magic solution to why this happened?? Thank you!
Here's my post: http://forums.autodesk.com/t5/Inventor-General/part-base-view-quot-Diplay-Option-gt-Thread-Feature-q...
Thanks for your input, Ladislav. I'm not certain the 'should default to the same status as previous IPT' is doing what it should. Please check against this workflow: create a fresh drawing template in 2013, which will have threads shown on by default. Make a part with threads. Make a base view of that part in 2014 using the 2013 template. I expect you'll find no threads. Apparently if you bump this up a year you'll see the same thing.
See solution here:
