I am sure I am overlooking something.. However, here it is:
I am trying to create a simple STD flat part that will be a piece of plate. I have parameters for Length, Width, etc... And I am setting up a User parameter for UOM_QTY which I want to spit out the SQFT all dimensions are in inches. So my equation is of course width*length/144. Is there a way to add this to the Unit/Type so that I can just select it? When I pick the Unit/Type cell in the parameters and expand area all I see is circular_mil. So can you add to these options? The sqft is essentially what I want to populate my BOM in addition to the Length, Width etc...
Am I even making sense?
Thanks!
Solved by cbenner. Go to Solution.
Solved by mrattray. Go to Solution.
You can manually type in compound units. Type in: ft*ft
That should make your conversion unnecessary as well.
From the Wiki help on units in parameters:
To build a compound unit specification, such as in/sec, separate the individual units with the appropriate sign of operation, such as multiplication, division, or exponentiation.
So for square feet you would enter ft*ft, which shows up in the parameter as "ft^2". I haven't tested this with real parts, but give it a shot.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Unfortunately this wont allow you to use area units as Base Unit in modelling parameters because "Only parameters that have a value that are units of length, volume, or mass are valid."
Source - http://augi.typepad.com/augi_news/files/iv10_bom_whitepaper.pdf
To get things improved in one of next releases it probably worth to vote for the idea - http://forums.autodesk.com/t5/Inventor-IdeaStation/Area-units-in-Base-Quantity/idi-p/4387795
