Parameter table not showing up
jps76
Message 1 of 10
jps76
I'm working on a part and when clicking on the parameter button the table does not appear.
The button goes blue so I know it has been selected, and I have tried using 1/2 monitors in case that was the issue but it will not show up.
And yes I have tried turning it on and off again 😂
Replies (9)
Message 2 of 10
EdvinTailwind
Once you have pressed the fx-button and it turns blue, you could try revealing the lost window by pressing Windows-key +  Arrow-Left/Right  a few times. This is a way to reposition a window without actually knowing where it is, or having to use the mouse.
In case this is a bug, you should tell which version you're using.
Message 3 of 10
jps76
I have tried that I'm afraid.
I think I am on 2023.3 but am not sure how to check
Message 4 of 10
JDMather
@jps76
Have you rebooted the computer and this behavior persists.
Can you Attach a file here that exhibits this behavior?
Message 5 of 10
jps76
Yes, I have tried rebooting the PC.
This is what happens once I click the button, just nothing shows up
Message 6 of 10
EdvinTailwind
The version number is in the top right ?-menu -> About...
Message 7 of 10
jps76
Message 8 of 10
Alexander_Chernikov
Hi,  this the base version.
You should update it to 2023.3
Do you find the posts helpful? "LIKE" these posts! | Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням!
Have your question been answered successfully? Click "ACCEPT SOLUTION" button. | На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ"
Олександр Черніков / Alexander Chernikov
Facebook | LinkedIn
Message 9 of 10
johnsonshiue
Hi! This has been discussed before. Somehow the dialog was improperly resized. Please take a look at this thread.
https://forums.autodesk.com/t5/inventor-forum/parameter-dialog-box-not-showing-up/td-p/5760616
If it does not work, go to Program Files -> Inventor Reset Utility and reset all settings back to install default.
Many thanks!
Software Test Engineer
Message 10 of 10
jps76
Thank you @johnsonshiue, that worked.
Clicking alt+space, then clicking size rather than move, and clicking an arrow key did the trick
