Inventor 2024 Ipart not working when extended names is enabled in borwser display setting
david_ernhoffer
david_ernhoffer
Hi!
My issue is the following in inventor 2024.
I have an ipart with couple of features - some of them have to be suppressed.
I made a feature in factory scope, then went to the ipart table and on the suppression tab I added that feature and wrote "Suppress" in the cell. Then verified the ipart table. After this action nothing has changed, the feature is still visible when it shouldn't be.
I did some digging, and found out if i turn off extended names setting, the method above does work and suppresses the feature.
It seems like the extended name setting causes inventor to not recognize the feature.
On the example the Face draft (x45 degree) is the test feature.
Without extended names the table does work, but with extended names enabled the "Suppression" has no effect.
In inventor 2023 even when the extended names setting is enabled the long name not shown in the table and it works well.
I find it really weird and annoying.
Thank you for any help regarding the issue.
Best Regards - David Ernhoffer
johnsonshiue
Hi! The behavior does not look right to me. It might be an unintended behavioral change in the table-edit workflow. If possible, please share the iPart factory here or send it to me directly johnson.shiue@autodesk.com. I would like to understand it better.
Many thanks!
Software Test Engineer
david_ernhoffer
Dear Johnson!
I have attached the factory ipt.
Another weird behaviour I found.
On the suppression tab i added the extended name feature, because it did not work I suppressed it from the model tree and it created another feature without the extended name in the ipart suppression table and that was the working one - I had 2 columns of the same feature in the suppression table - 1 with extended name 1 with short.
Thank you for your help.
johnsonshiue
Hi! Did you contact Autodesk Product Support and report the issue? If yes, the team is in the process of reporting a defect. It does look like a bug to me. Before a fix becomes available, I suggest you turn off the "Display extended information" option in Tools -> App Options -> Part.
Many thanks!
david_ernhoffer
Hi!
Thank you for your inshight, I have reported the issue.
johnsonshiue
Hi! Just to provide an update on this issue, I have noticed that it was reported as INVGEN-68821. The project team will take a look and see how we can fix it safely.
Many thanks!
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
