Shaped Centre Lines
Shaped Centre Lines
MikeKovacik4928
Advisor Advisor
Shaped Centre Lines
MikeKovacik4928
How do get a center line to follow a shape, ie as if you were offsetting a continuous line in a sketch.
I don't want all those overlaps I got using the centre line command where you can only select a single edge and then its opposite edge. I want to select a whole series of joined tangential lines as my first selection and then another
series of joined lines as my second selection. Like I said, almost like the offset command and then making the offset a chain line.
I can do this in a sketch, but want to know if there is particular center line command or way of using it
to produce the same effect
Mike Kovacik
South Africa
mluterman
I would do that in a sketch, but not in the .dwg view, I would do it at the .ipt level, this way it always stays (and is linked) with the part. Then, in the .dwg, click "Get Model Sketches" (in Part Priority) and "Include" in the Browser Tree to see it in your .dwg view (as long as the plane that contains the sketch is parallel to the sheet plane of the .dwg).
cadman777
Amazing that this stupid drafting defect still hasn't been fixed in well over a decade. How sad! 🤡
... Chris
Win 7 Pro 64 bit + IV 2010 Suite
ASUS X79 Deluxe
Intel i7 3820 4.4 O/C
64 Gig ADATA RAM
Nvidia Quadro M5000 8 Gig
3d Connexion Space Navigator
mluterman
Yup!...and that's why I can't bear to visit the Ideas Forum.
MikeKovacik4928
I will give that a try
Mike
cadman777
Ha, good reply! Yup, they created that worthless idea forum after I quit giving them good advice. I quit b/c I realized they don't give a rip about our expert opinions. All they give a rip about is their investor profits. We end users are their 'picking field' for revenues (stock ratings). That's how all bureaucrats and business people look at us corporate slaves. Leeches...social parasites one and all!
... Chris
ASUS X79 Deluxe
64 Gig ADATA RAM
mrB_Young
Your comment made go look at the ideas forum ... I see where you're coming from
Inventor user since 2009
Vault user since 2010
