Can you continue to work In Inventor or does it appear like its locked up? YOu may have it off the screen.. Use Alt+spacebar, m key, select a right or left arrow key and move your mouse.
Mark Lancaster
& Autodesk Services MarketPlace Provider
Hi, thanks for your response.
I can continue to work in Inventor.
The parameter dialog box still does not show up. It was working fine this morning, and i even have an excel sheet ready with a list of parameters in the expected format.
Joseph Thodiyil
I am having this issue now. It is as if the Parameter box has gone invisible. Did you ever solve this issue?
Hi scody47ZUS ,
Have a look at this link for information on how to get the Parameter dialog box back on the screen, assuming this is the issue:
http://inventortrenches.blogspot.com/2011/01/missing-dialog-box.html
I hope this helps.
Curtis
Just for general information the Parameter dialog is non-modal, so it allows you to keep working when it's off screen, so the "locked up" behavior would not be present in this particular case.
