parameter dialog box not showing up
Can you help with this?
Mark.Lancaster
Can you continue to work In Inventor or does it appear like its locked up?   YOu may have it off the screen..  Use Alt+spacebar, m key, select a right or left arrow key and move your mouse.
Mark Lancaster
Hi, thanks for your response.
I can continue to work in Inventor.
The parameter dialog box still does not show up. It was working fine this morning, and i even have an excel sheet ready with a list of parameters in the expected format.
Joseph Thodiyil
I am having this issue now. It is as if the Parameter box has gone invisible. Did you ever solve this issue?
Curtis_Waguespack
Hi scody47ZUS ,
Have a look at this link for information on how to get the Parameter dialog box back on the screen, assuming this is the issue:
http://inventortrenches.blogspot.com/2011/01/missing-dialog-box.html
I hope this helps.
Curtis
Curtis_Waguespack
Just for general information the Parameter dialog is non-modal, so it allows you to keep working when it's off screen, so the "locked up" behavior would not be present in this particular case.
Hey,
Thanks for the help. Actually the alt+space, followed by "move" did not solve the issue. It would only show my mouse moving across the screen. However, it was solved by alt+space, "size", and then clicking the left arrow. Apparently there was some sort of bug that made it invisible, and resizing it solved it.
