Hi all,
For a project of mine i want to export a variable parameter lets Call this X but this parameter is dependent of the Plane called Y_layer.
So when te the plane Y_layer moves 1mm the variable X changes the value of X needs to be exported in an excell file. When the Y_layer moves again 1 mm then the value of X changes and that value needs to be written in another excell cell. when the Y_layer moves again the value of X changes and needs to be written in a new cell.
Could someone help me please
I use inventor 2017
Greetz Lowie
Wel i tried it and i didnt get the save errors any more so thats good. But i the values in excel are still the same.
New code
:SyntaxEditor Code Snippet
If Start= True Then Do While Afstand_tot_center_Ruit <5 Afstand_tot_center_Ruit= Afstand_tot_center_Ruit+0.5 InventorVb.DocumentUpdate(True) 'Define the excel columns A to D to write to: Cell_X1="A" & Row_no Cell_X2="B" & Row_no Cell_Y1="C" & Row_no Cell_Y2="D" & Row_no Cell_H1="E" & Row_no Cell_H2="F" & Row_no 'Write the values GoExcel.CellValue("C:\Users\lowie\Documents\Inventor\laser_cladder_Lowie\X1.xls", "Blad1", Cell_X1) = X_Afstand_1_Ruit GoExcel.Save GoExcel.Close GoExcel.CellValue("C:\Users\lowie\Documents\Inventor\laser_cladder_Lowie\X2.xls", "Blad1", Cell_X2) = X_Afstand_2_Ruit GoExcel.Save GoExcel.Close GoExcel.CellValue("C:\Users\lowie\Documents\Inventor\laser_cladder_Lowie\Y1.xls", "Blad1", Cell_Y1) = Y_Afstand_1_Ruit GoExcel.Save GoExcel.Close GoExcel.CellValue("C:\Users\lowie\Documents\Inventor\laser_cladder_Lowie\Y2.xls", "Blad1", Cell_Y2) = Y_Afstand_2_Ruit GoExcel.Save GoExcel.Close GoExcel.CellValue("C:\Users\lowie\Documents\Inventor\laser_cladder_Lowie\Hoek_1.xls", "Blad1", Cell_H1) = Hoek_1_Ruit GoExcel.Save GoExcel.Close GoExcel.CellValue("C:\Users\lowie\Documents\Inventor\laser_cladder_Lowie\Hoek_2.xls", "Blad1", Cell_H2) = Hoek_2_Ruit GoExcel.Save GoExcel.Close Row_no= Row_no+1 Loop End If
But what i think seems to be odd is that when i delete this bit of code that automates the moving of Y_layer then it works. But when i add this code back to automate it doesnt work so it has nothing to do with my excel i also have no errors about saving or already being opend.
If Dikte > 10 Then
While Dikte < 100
Dikte = Dikte +10
MessageBox.Show("Stap bijtellen","Nr 1")
num = num+1
cell = "A" + CStr(num)
GoExcel.CellValue("C:\Users\lowie\Documents\Inventor\test123\test123456.xls", "blad1", cell) = Dikte
End While
The code above is an automated piece when the dikte changes 1 mm above 10 mm then it wil add 10 mm in steps and write it down in excel in separte cells actually just like i want. But why doens't that work with the code underneath they are the same in theory not?
Does it matter if the paramater that i try to write in excel is a reference parameter ? SyntaxEditor Code Snippet
X_Afstand_1_Ruit
Well there is a difference between Inventor parameters and variables so the difference in your small and real code might be in that.
What you could try is making the row_number a variable and remove it as parameter.
As said before, I have a lot issues less than you do. But you are saying that you only see 1 value in Excel or is it printing a whole list of identical values?
I'm really running out of ideas why this goes wrong.
Hi Lowie,
Have you installed the SDK (software developers kit), once you do this, there is a Object Model PDF file.
Here you can see which objects you can manipulate within VBA.
Install from here: C:\Users\Public\Documents\Autodesk\Inventor 2017\SDK
Cheers
Jon.
@Anonymous wrote:
Would you know if there is any way to make this happen in VBA ?
Hi lowie.lesschaeve,
Also, just a reminder that, you can search and ask programming questions of this type on the Inventor Customization forum too:
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
I hope this helps.
Curtis
