Hi!
I'm trying to create a basic parachute using inventor, and I came across this model I attached, but I need to do it with my specific measures.
Does anybody know how can I make this?
Any help would be appreciated.
Thanks.
Attach the *.ipt file of your attempt here.
With Inventor - you simply edit dimensions to change them to whatever you need.
I dont have an .ipt file, I download the .STEP file from somewhere, I'll attach it anyways.
Here's a parametric file (2016 IPT).
Geometry can be changed in Parameters window
Walter Holzwarth
Thank you sir! Real life saver here 😉
I'm trying to change parameters but it says that edits are not allowed on the file. How can I do it?
Thanks back. Good to see that sometimes life is not too complicated ..
Later: Edits are not allowed? Can you show a screenshot of the message?
Walter Holzwarth
I tried redownloading the file and it is working right now, I don't know why it didn't work before. Everything's ok right now.
Thank you again! There was no way I'd be able to do that in 2 days with the knowledge I have on Inventor hahaha.
Times are changing.
Several years ago Inventor was presented as one-day-productivity-tool.
But meanwhile Inventor got lots of more functionality. Learning curve is steeper now.
Walter Holzwarth
