Inventor Forum
Paint allowance in Autodesk Inventor 2015
6 REPLIES 6
505 Views, 6 Replies
Hi
Does anyone know if its possible to add a 0.5mm powder coat allowance over selected parts. At present im working with mild steel and I need to take into account the fact powder coat will reduce tolerances
6 REPLIES 6
CCarreiras
Hi!
You can add the thickness to represent the powder coat.
If you chose multibody, you will have the coat and the part.
CCarreiras
Will give this a go thanks for the help. Will update the thread if I manage to complete it
in reply to: CCarreiras
Im struggling to find the multibodies command in my part file?
JDMather
Multi-body is simply part of the feature creation process.
Select Thicken and the New Solid option of Thicken (or Extrude, or Sweep, or....)
Another technique is to Derive Component as a Surface Body and then Thicken.
JDMather
Did you figure this out?
in reply to: JDMather
Yeah thanks figured it out now 😄 its under the split/combine/thicken ribbon
