Hi!
You can add the thickness to represent the powder coat.
If you chose multibody, you will have the coat and the part.
Multi-body is simply part of the feature creation process.
Select Thicken and the New Solid option of Thicken (or Extrude, or Sweep, or....)
Another technique is to Derive Component as a Surface Body and then Thicken.
Did you figure this out?
