- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
As the name basically says, while i'm in the Assembly enviroment / file in ADSK INV 2023 i want to as usual edit an individual part and for example in the video i'd like to still see the 3D Scan data and all other parts to make the right size part around everything and job done.
But a few weeks/months ago i started having this issue where when i am working in an assembly file, and i click into one of the parts to edit, all the other IPT's or objects cancel out entrierly instead of just turning transparent like usual.
Any suggestions?
I can share the file if required.
@JDMather @johnsonshiue - i hope you guys don't mind the tag, i see your feedback in alot of posts and figure you might know exactly what the issue is.
