Inventor Forum
ordinate datum value
2 REPLIES 2
justin_chadburn
493 Views, 2 Replies
Hi
Is it be possible to set a value for the ordinate datum that isn't zero? I know this is not what inventor was designed for, but we often have to display AOD levels. I would like to set a known point to say 42.350 (M AOD) and work from there.
Thanks in advance
Justin
kelly.young has embedded your image for clarity.
2 REPLIES 2
Hi Justin,
Indeed, this is not how Inventor was designed to work. But, you could sort of do that. Place the origin indicator attached to a view vertex. Right-click on it -> Edit -> you can define the X and Y offsets from this point. The origin indicator will be relocated accordingly. You can right-click on it and hide it. Now, the geometry you pick to create ordinate dimensions will be based on this new origin.
Many thanks!
Software Test Engineer
That's exactly what I wanted to do, thanks.
I've also just figured out how to change only this dimension set to meters by creating a new dimension style and using "copy properties" to apply to the others. This now gives me my M-AOD measurement which is far easier than using leaders and forgetting to change the values when the levels change.
Cheers
