Inventor Forum
open model from excel speadsheet.
3 REPLIES 3
warrentdo
341 Views, 3 Replies
Is it possiable to open a model from a list within excel?
My intension is to create a spread sheet that people can write to them create through i-logic rule that opens up each model, create a DWFX, then close the model and then open up the next model taken from the excel spread sheet and create the dwfx etc.
I have created one an rule that will create a dwfx from the open document. (oFileName = ThisDoc.FileName(False) 'without extension)
Thanks in advance.
Warren
'------start of iLogic-------
oPath = "X:\Projects\P15184\10 Drawings\Mechanical\Working\REVIEW\"
oRevNum = iProperties.Value("Project", "Revision Number")
oDWFAddIn = ThisApplication.ApplicationAddIns.ItemById _
("{0AC6FD95-2F4D-42CE-8BE0-8AEA580399E4}")
oDocument = ThisApplication.ActiveDocument
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
oFolder = "d:\warren\"
If oDWFAddIn.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then
   oOptions.Value("Launch_Viewer") = launchviewer
   oOptions.Value("Publish_All_Component_Props") = 1
   oOptions.Value("Publish_All_Physical_Props") = 1
   oOptions.Value("Password") = 0
   oOptions.Value("Publish_3D_Models") = Publish_3D_Models
   If TypeOf oDocument Is DrawingDocument Then
       Dim oSheets As NameValueMap
       oSheets = ThisApplication.TransientObjects.CreateNameValueMap
       oOptions.Value("Publish_Mode") = DWFPublishModeEnum.kCustomDWFPublish
       oOptions.Value("Publish_All_Sheets") = 1
       ' Publish the first sheet AND its 3D model
       Dim oSheet1Options As NameValueMap
       oSheet1Options = ThisApplication.TransientObjects.CreateNameValueMap
       oSheet1Options.Add("Name", "Sheet:1")
       oSheet1Options.Add("3DModel", True)
       oSheets.Value("Sheet1") = oSheet1Options
   End If
End If
'get dwf target folder path
oFolder = Left(oPath, InStrRev(oPath, "\"))
'Set the DWF target file name
oDataMedium.FileName = oFolder & "\" & oFileName & " "& oRevNum & " Check Drawing" & ".dwf"
'Publish document
oDWFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
i = MessageBox.Show("View the DWF file?", "Title",MessageBoxButtons.YesNo)
If i = vbYes Then : launchviewer = 1 : Else : launchviewer = 0 : End If
If launchviewer = 1 Then ThisDoc.Launch(oDataMedium.FileName)
'------------------- End Complex code added In To save all sheets --------------
3 REPLIES 3
mcgyvr
in reply to: warrentdo
You can just create a hyperlink in Excel to open any files.. inventor files included..
However...any reason you don't just use task scheduler to batch publish dwf files?
Or just setup auto dwf publishing on save trigger via ilogic?
Or if you use vault I thought it would automatically create dwf files..
warrentdo
in reply to: mcgyvr
Hello Mcgyvr,
We are only doing a sellection of the files (5%) and not all.
Task scheduler means that you have to add the file to the task and we would have 3 different users at three different sites adding files.
It would be easier if they all have access to spread sheet that they could add the files to then run the logic from the spreadsheet?
Save on trigger is slowing down the model 'save' as the files may be saved a few times a day and they are quite large files. Also this would catch all files and not the 5%.
Vault DWF create leads to problems with the file name .iam.dwf and also vault doesnt create the dwfx with custom iprops (but I may be wrong)
it is disabled due to dwfx overhead.
I just thought that each user filling new files into a speadsheet then run the i-logic at the end of the week would work the best?
Cheers,
Warren.
warrentdo
Hello all, any more for opening a set of Models from a speadsheet to then create dwfx from them?
Warren.
