old/original files are linked with copy design files
er.rohanmore
er.rohanmore
Hello All,
After the successful copy design in the vault when we get files from the vault and open the files in the Inventor, old/original (source) files are still linked to the new copy design file (.iam or .idw).
We need to delete the original files from the local drive and then relink all new files. This task adds one more step to the workflow and is tedious in the case of large assemblies.
Has anyone faced the same issue?
Any solution to avoid this problem?
Many Thanks.
Frederick_Law
Files that are renamed will be new copy.
Files that are NOT renamed will be reused and linked.
Check your Copy Design settings.
er.rohanmore
@Frederick_Law
All files are renamed and no reuse of any file.
Thanks.
Frederick_Law
That should not happen.
Some thing wrong when you Copy Design.
johnsonshiue
Hi! Is this Vault Copy Design or iLogic Design Copy or Design Assistant? If possible, please share the files in zip here or send it to me directly johnson.shiue@autodesk.com. I would like to understand the behavior better.
Many thanks!
Software Test Engineer
er.rohanmore
This is vault copy design. Once we perform regular copy design and get file
from local drive. Old files are still linked to the new file.
johnsonshiue
Hi! I am sorry I am not a Vault expert. But I thought there should be options in Copy Design to keep the old links or remap to new files. Here is a related article. I am not sure it is the same issue though.
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Copying-Inventor-p...
Many thanks!
