Offset surfaces
Offset surfaces
ToddPig
Offset surfaces
ToddPig
A typical workflow (in Solidworks) for creating a wire, would be to add a new part to an assembly, and then edit this new part.  I then would be able to use the offset surface feature (with a value of zero), and click both the start and end surfaces, but also any reference surfaces I wanted to avoid, go around, or through.
I'm looking for the Inventor equivalent workflow,
Thanks in advance,
Todd
Inventor 2018
(23+ years of Solidworks, 5+ years of fighting Inventor)
Autodesk Vault Pro 2018
iParts = iHeadache
TheCADWhisperer
Copy Object - set Surface as output.
ToddPig
Perfect, THANKS!!!
Inventor 2018
iParts = iHeadache
