Inventor Forum
OCE' 9400 and OCE' 9600 plotter setup for IV8
2 REPLIES 2
202 Views, 2 Replies
We have two plotters that we use, OCE' 9400 and OCE' 9600. The OCE' 9400 plots to a LPT port. I have tried to use every configuration in print layout to get a "D" or "C" size print to fit correctly on the page. The preview show the print correctly, but the plot is rotate comes out rotated the 90 degrees and we end up cutting the excess off of the print.When I try to fool the printer and rotate the preview 90 degrees, the same thing happens, except the plot is reduced to the next size. Has anyone successfully set up this plotter for Inventor?
Our OCE' 9600 is set up to retrieve all pots from a print que on our server. When we plot an AutoCAD drawing, we plot to a file, and send a ".plt" file to the que. I have not found a way to set up this plotter in Inventor. It does not show up on the list of available plotters. Am I missing a driver or some type of setup?
Any suggestions, Please advise.
Moderator; If this is not where this post is supposed to be, would you please re-post to the correct location.
Thank you.
Rocky Brown
Aluminum Ladder CO.
erb@carbis.net
2 REPLIES 2
Hi - You may find more specific OCE information in the print/plot discussion group. NNTP discussion group readers use news://discussion.autodesk.com/autodesk.autocad.print-plot HTTP web-based group uses http://discussion.autodesk.com/forum.jspa?forumID=30. --- Anne Brown Discussion Groups Administrator Autodesk, Inc erbrown wrote: > (snip) > Moderator; If this is not where this post is supposed to be, would you please re-post to the correct location.
Thanks Anne. I will re-post this there.
Rocky Brown
Aluminum Ladder Co.
erb@carbis.net
