Nvidia Control Panel and Inventor Settings
Message 1 of 31
 1 month ago I bought a PC with the following settings:
- Motherboard Gigabyte GA-X99-UD3
- Intel Core i7 5820K 3.30GHz 15MB
- Water Cooler CM Seidon 120M
- Memory 32GB DDR 2400MHz Kingston Fury (4x8)
- HD SSD 240GB Kingston V300
- HD 1Tera SATA3 Seagate 7200RPM
- Video card PCI-express 8GB PNY Nvidia Quadro M4000 256bit
I use every day Autodesk Inventor 2015 software, but when I do some rendering 15 seconds in Inventor Studio takes over 4:30 hours.
Another problem is when I open a large assembly my pc get some lags.
Can anybody help me ? I believe that if I adjust the Nvidia Software settings and inventor settings, I can solve my problems.
But I do not know how to do this.
Replies (30)
Message 2 of 31
mdavis22569
Welcome to the forum ....
What is your hardware setting under application options?
Also are you up to date on your video card drivers?
As for the rendering, depending on how and what you're rendering it could take a lot time, but it also lets you keep rendering til satisfied ..
I've done 5 reiterations and 400 of a image in Studio, ..  what are you using for settings?  4000 x 4000 ?
Mike Davis
Message 3 of 31
Hey,
-Sorry I dont understand what you mean with "What is your hardware setting under application options?"
-My video card is already updated with the new version
- I tried to render only for testing.
I used an assembly with only 70 parts, resolution of 640 X480, Highest antialiasing, 60 frame and 15 seconds just by changing the camera, and it would take 4:30 hours.
I know this Pc i can get much better, so I'm still thinking that the problem is on the Nvidia control Panel and the Inventor settings.
Message 4 of 31
mdavis22569
this is the setting I was talking about application options .... ALso is your Inventor fully up to date with Patches and updates
is it rendering or Rendering Animation?
Mike Davis
Message 5 of 31
@mdavis22569   My hardware settings is on Quality ..
 15s of rendering animation
Message 6 of 31
mdavis22569
also for the opening lag ... (that shouldn't be video card related )
are you working with Vault, locally or over a network
Mike Davis
Message 7 of 31
mdavis22569
change it to performance ...and see if you're ok with that quality. I do Hi-Res images ...and I'm on performance without any issues
Mike Davis
Message 8 of 31
mdavis22569
also make sure you have all the updates etc
https://knowledge.autodesk.com/support/inventor-products/downloads?release=2015
I believe there are 15
Mike Davis
Message 9 of 31
I`m work locally.
Do you know how can configurate on Nvidia control ,the manager 3d settings for inventor .
Message 10 of 31
mdavis22569
i do not ....sorry.
I don't change anything on either of my Geforce Nvidia cards ... but I'm not having an issue.       What are you trying to change?
Why do you believe it's related to the Control panel, did you start doing changes in it?   Maybe see if you can change it back to default settings if so ..
M
Mike Davis
Message 11 of 31
Yes, I tried change to get better .
I heard that you can make changes that can greatly improve the system and the use of the video card, but I do not know what can I adjust.
Message 12 of 31
mdavis22569
here is a post similiar ...
https://forums.autodesk.com/t5/inventor-general-discussion/inventor-2015-work-but-has-a-lag/td-p/571...
maybe this will help
Mike Davis
Message 13 of 31
@mdavis22569 I'm trying to render a Image with 1024 x728  and hight antialiasing  with 300dpi. but the picture is unfocused and without quality.
any help?
Message 14 of 31
blair
Make sure that you have your system hardware set to default and are not "Overclocking" anything. Last week someone posted of poor performance running an Inventor system test. It appears that a couple of "Overclock" settings were incorrect which caused his system to slow down considerably.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 15 of 31
dgorsman
A couple of points:
  • Inventor doesn't use the video card for rendering, as in creating images or movies.  The process is strictly CPU based so no amount of video card tweaking will help.
  • 4.5 hourse for 15 seconds of animation is about right.  Consider that 15 seconds run-time x 24 frames per second is 360 frames; 1 minute render time for each frame is 360 minutes, or 6 hours.
  • The larger the image (in pixels, not DPI) the longer it will take to render each frame.  The higher the quality the longer it will take.  Its not at all unusual for a large, high-quality image to take several hours to render.
Message 16 of 31
@blair
I am layman for that kind of stuff, could you teach me how do I check this?
Message 17 of 31
mdavis22569
Sorry cadumoret I'll be back in another hour or so ... Family event. Can you share an image to see what you have. I think you like need to try 2000 x2000 and then you can zoom in and not get the blur effect
Mike Davis
Message 18 of 31
mdavis22569
Mike Davis
Message 19 of 31
mdavis22569
So here is what I have set up for my nvidia 9500 GT
The image above was done on this machine ....
Maybe restore it back and see how it does .... and change your Application setting to Performance ...
Also make sure you have all of the Inventor updates as well ...and then can you share an image of what you're getting.
Mike Davis
Message 20 of 31
I have that problem (picture) but I don't know what should I do to solve that.  Sorry is not in English.Pc.png
