numerate my dimension
eladm
Message 1 of 16
eladm
Hi Inventor users
Is someone have an idea how to numerate all my drawing dimensions ?
After I finished my drawing , I want to add number near each dimension
it think it is a rule
best regards
Replies (15)
Message 2 of 16
mdavis22569
I've not seen a way ...
Maybe to help some of us better understand...
What's the end goal/reasoning for it?
Might be a different solution possible
Mike Davis
Message 3 of 16
eladm
Hi
The main goal is to add number near each dimension 1,2,3,4 ....
(if I have 12 dimensions in the drawing(idw file) i will have 1,2,3 ... 12 )tommorw I will add one more dimension the number 13 will be add near this dimension . it can be like a symbol number inside a circle
regads
Message 4 of 16
johnsonshiue
Hi! I guess you can use a sketch symbol. If this particular sheet only contains drawing views of a part, you could use Balloon command to do that and override each number manually.
Many thanks!
Let us know how we did on Trustpilot.
Software Test Engineer
Message 5 of 16
eladm
I want that the number will add automatic
i think the answear need to be iogic rule
Message 6 of 16
mdavis22569
If you could do iLogic, how does it know the order?
You would need to run the rule after each dimension is added then ...
What happens if they use the auto-retrieve dimensions, that would / could conflict with the iLogic.
Mike Davis
Message 7 of 16
eladm
correct , only after all the dimensions is in the drawing I will run the rule. the ordef not impornent (for now)
Message 8 of 16
ThomasB44
Hi @eladm
Here an example of a rule to add an unique number to each dimension.
It doesn't add a balloon style...Smiley Embarassed
SyntaxEditor Code Snippet
Dim oDrawingDoc As DrawingDocument
    If ThisApplication.activeDocument.DocumentType <> kDrawingDocumentObject Then
        Return
        Else
        oDrawingDoc = ThisApplication.activeDocument
    End If
Dim oSheet As Sheet
oSheet = oDrawingDoc.ActiveSheet
Dim oDims As DrawingDimensions
oDims = oSheet.DrawingDimensions
Dim oDim As DrawingDimension
Dim oDimText As DimensionText
Dim i As Long
i = 1
For Each oDim In oDims
    oDimText = oDim.Text
    oDimText.FormattedText = "<DimensionValue/>" & " ( " & i & " )"
i = i + 1 Next
 Edit : I forgot to add the line with "i = i + 1" Smiley Tongue
Thomas
Mechanical Designer / Inventor Professional 2025
Inventor Professional EESignature
Message 9 of 16
eladm
Hi Thomas
Thnank you very much
did you forget to add the line ? i = i + 1
it not working to hole and thread  notes (it must be because thay act different from dimension )
best regards
Message 10 of 16
ThomasB44
Yes, I realised that I forgot the line, so I've edited my post Smiley Wink
To add the thread notes please see the new rule :
        Return
        Else
    End If
Dim oSheet As Sheet
Dim i As Long
i = 1
    i = i + 1
Next
Dim oThreadNotes As HoleThreadNotes
oThreadNotes = oSheet.DrawingNotes.HoleThreadNotes
Dim oThreadNote As HoleThreadNote For Each oThreadNote In oThreadNotes oDimText = oThreadNote.Text oDimText.FormattedText = "<DimensionValue/>" & " ( " & i & " )" i = i + 1 Next
Thomas
Message 11 of 16
ThomasB44
Hi @eladm
Does the rule I gave finally help you ?
Thomas
Message 12 of 16
eladm
Hi Thomas
It help a-lot , I see that if the first dimension deleted and run the rule again , the 2nd dimension get the number 1 and so on ,it is wonderful start .it look simple and very good
Message 13 of 16
kelly.young
Autodesk Support
Autodesk Support
Hello @eladm I used to use this in the aerospace industry when marking drawings with bubbles for inspection. Although that way is pretty sweet you might have it where some dimensions you don't want inspected or need to re-number, I can see it being hard to edit or customize.
Thought I would recreate how I used to do it and share. Found a bit of code by @mcgyvr that might work for this.
I can't remember how to get it to Run the Rule on Sketch Symbol Placement, but as you can see from the screencast it is very close.
INCREMENTCurrent = iProperties.Value("Custom", "INCREMENT")
INCREMENTNew = INCREMENTCurrent + 1
iProperties.Value("Custom", "INCREMENT") = INCREMENTNew
RuleParametersOutput()
iProperties > Custom Tab > Name: INCREMENT, Type: Number, Value: 1
Annotate > Symbols > Define New Symbol
Maybe someone with advanced iLogic experience can add the final touches? I had it years ago where every placement would automatically increase the number ready for the next placement but can't remember the last bit. Thanks!
Please select the Accept as Solution button if a post solves your issue or answers your question.
Message 14 of 16
Curtis_W
Hi eladm,
Building on what ThomasB44 provided, here is a version that uses Inventor's built in Inspection Dimension tools to do this.
Also just as a tip, you can search and ask programming questions of this type on the Inventor Customization forum too:
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
I hope this helps.
Curtis
        Return
        Else
    End If
Dim oSheet As Sheet
Dim oDims As DrawingDimensions oDims = oSheet.DrawingDimensions Dim oDim As DrawingDimension Dim i As Long i = 1 For Each oDim In oDims oDim.IsInspectionDimension = True oDim.SetInspectionDimensionData _ (InspectionDimensionShapeEnum.kRoundedEndsInspectionBorder, i) i = i + 1 Next Dim oThreadNotes As HoleThreadNotes oThreadNotes = oSheet.DrawingNotes.HoleThreadNotes Dim oThreadNote As HoleThreadNote For Each oThreadNote In oThreadNotes oThreadNote.IsInspectionDimension = True oThreadNote.SetInspectionDimensionData _ (InspectionDimensionShapeEnum.kRoundedEndsInspectionBorder, i) i = i + 1 Next
Message 15 of 16
eladm
Hi Curtis
Thank you
best regards
Message 16 of 16
I found this really helpful for me, but the problem is that when I save .idw and open it again, all numbers change to the last value. Is there some solution which should I add to the current code?
