Inventor Forum
Increment custom iproperty value using ilogic
3 REPLIES 3
844 Views, 3 Replies
I would like to know the possibility of incrementing custom iproperty parameter value.
Let say, i had created custom iproperty by name "increment" and set the value to "01" initially.
Now, I have to write a ilogic code in such a way that, whenever if i make any parameter change/geometry change, custom iproperty have to increment the value like "01,02,03,04 and so on".
Please let me know how to do this.
3 REPLIES 3
mcgyvr
Caution.. I'm not good at this.. But it works.
INCREMENTCurrent = iProperties.Value("Custom", "INCREMENT")
INCREMENTNew = INCREMENTCurrent + 1
iProperties.Value("Custom", "INCREMENT") = INCREMENTNew
in reply to: mcgyvr
Thank you very much, the code is working fine.
in reply to: mcgyvr
I found this really helpful for me, but the problem is that when I save .idw and open it again, all numbers change to the last value. Is there some solution which should I add to the current code?picture.PNG
