Not appear Library flexible pipes
mitsa
mitsa
Hello, I have inventor pro 2018, and I need create flexible pipes, but not appear in the library. Inventor Pro include this library or I will be need download?
Marco Lizana
Mark.Lancaster
@mitsa
The information belonging to this style is part of the Inventor Parker content center library.  Assuming you're using Inventor Desktop Content Center, when you installed Inventor did you select PARKER as one of the libraries to install?  IF you go to your active project file, select config content center  libraries (icon lower right hand corner) is parker selected?
Mark Lancaster
mitsa
Mark thanks for your answer. Yes your right, I have not select parker, now I select parker and appears the library flexible pipes.
Thanks again.
Marco Lizana
