Something has happened with my Inventor 2017 installation, the offset command do not create relevant constraints. The screencast shows how this work on one computer (2017.3 running on Winodws 10).
On the other computer (Inventor 2017.3 running on windows 7), constraints are added as they should. The offset relation between the two curves are kept by a number of constraints placed by the offset command.
Constraint settings are the same on both computers, inference for all constraints and persist are set.
Any suggestions?
Torbjørn
(Inventor 2017.3)
Solved by JDMather. Go to Solution.
