Hello:
I need an expert designer to create 3D files of two plastic prototypes. The difficulty with them, according to those I have talked with so far, is that they are not symmetrical. Estimates were approximately 30 mins for each, but the results were unsatisfactory.
Please get in touch if you can help.
Solved by Xun.Zhang. Go to Solution.
Post the shape of the parts and what have you got so far in modeling the parts.
Igor.
Hello again,
Images were well-received and a sample has been sent to you for reference, there are many ways to handle, but you have to create several sections with guidelines and leverage command Loft to do so, after that, you can either make a solid and try to make a shell or just thicken it, either of them is working for you.
Hope it helps!
