Inventor Forum
Dimension Position
4 REPLIES 4
lkirit2000
539 Views, 4 Replies
Dimension Position
Hi.
Please see the attached image. I would like to bring the dimension 130 between arrow marks.
Rgds
4 REPLIES 4
Xun.Zhang
in reply to: lkirit2000
Just click and hold for the dimension value (130) and drag to the center.
Hope it helps!
Xun
lkirit2000
in reply to: Xun.Zhang
Hi Xun,
Thanks for your prompt response. I have already approached that method and it didn't work !
Rgds
Xun.Zhang
Sounds like there is not enough space for the dimension in the middle, you'd better to scale the view a little bit to make it larger.
Hope it helps!
Xun
jhackney1972
As Mr. Zhang has said, if the dimension is to large to fit between the extension lines, it will not fit no matter what.  If there is room you can follow the method outlined in the screencast.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
