Hi.
Please see the attached image. I would like to bring the dimension 130 between arrow marks.
Rgds
Solved by jhackney1972. Go to Solution.
Just click and hold for the dimension value (130) and drag to the center.
Hope it helps!
Hi Xun,
Thanks for your prompt response. I have already approached that method and it didn't work !
Rgds
Sounds like there is not enough space for the dimension in the middle, you'd better to scale the view a little bit to make it larger.
Hope it helps!
As Mr. Zhang has said, if the dimension is to large to fit between the extension lines, it will not fit no matter what. If there is room you can follow the method outlined in the screencast.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
