I need to get a M8 x 1 thread in a 7mm nominal diameter hole.
By default, inventor uses a nominal diameter of 6.917mm for this thread and I'm not sure how to modify this.
I opened the file threads.xls in "S:\CAD\2 Inventor Default 2017\Design Data\XLS\en-US" and checked the values available. For a M8 x 1 thread/Internal/Minor Diam, the nominal hole diameter can be set between 6.917 and 7.153 but we don't have the choice in Inventor to set the actual value we want to use. The value used is by default the Min one, here 6.917 (see attachment).
How can we set the default values different from the minimal one? Do we need to modify the excel file or can we do it directly in Inventor?
Thank you,
Sylvain
