Inventor Forum
Nominal hole diameter for thread
25 REPLIES 25
Message 1 of 26
PLM-Sylvain.Bailly
8270 Views, 25 Replies
​Hi,
I need to get a M8 x 1 thread in a 7mm nominal diameter hole.
By default, inventor uses a nominal diameter of 6.917mm for this thread and I'm not sure how to modify this.
I opened the file threads.xls in "S:\CAD\2 Inventor Default 2017\Design Data\XLS\en-US" and checked the values available. For a M8 x 1 thread/Internal/Minor Diam, the nominal hole diameter can be set between 6.917 and 7.153 but we don't have the choice in Inventor to set the actual value we want to use. The value used is by default the Min one, here 6.917 (see attachment).
How can we set the default values ​different from the minimal one? Do we need to modify the excel file or can we do it directly in Inventor?
Thank you,
Sylvain
25 REPLIES 25
Message 2 of 26
S_May
in reply to: PLM-Sylvain.Bailly
Hi @PLM-Sylvain.Bailly,
Please in the excel edit for thread, then they have it the next time as they wish Smiley Happy
Message 3 of 26
yoann.fusco
in reply to: S_May
Hi Sascha,
Is there any other "more beautitful" way to do that without modifying the Min value in the Excel?
Something like choosing a value in Inventor within the range predefined in the Excel.
Thank you for your help,
Yoann
Message 4 of 26
May not work for every situation but, for the M8, could you reduce the precision of the pilot hole to no decimal places?
Message 5 of 26
mcgyvr
in reply to: yoann.fusco
@yoann.fusco wrote:
Hi Sascha,
Yoann
@yoann.fusco @PLM-Sylvain.Bailly
There are a few things that would help you guys out..
And neither involves editing the excel sheet because you don't need to as the information is correct..
If you need it to be 7mm because you are using this file to import directly into a CAM program or using it with HSM CAM program then you can change Inventor to use the "tap drill" size for the hole instead of the "minor" diameter.. You do that in "Tools..application options..document settings.. modeling tap and see the "tapped hole diameter" section.. Change it to "tap drill" and you will get your 7mm hole..
You could also just sketch a 7mm diameter circle and extrude/cut then use the thread tool to apply the M8 thread..
Is there another reason you want this 7mm referenced?
Message 6 of 26
S_May
in reply to: mcgyvr
I would prefer the excel as it can then be used in the company.
Of course with markings.
But that is just one way
Message 7 of 26
mcgyvr
in reply to: S_May
I don't Smiley Wink
The excel spread sheet is correct and shouldn't be changed.. The document setting/template should be set and would apply on a company basis and used that way "if" thats what they really need..
The only real reason (that I can think of now) for needing 7mm is because of direct use of the CAD file by CAM software.. other than that minor diameter should be used and tap drill can easily be called out if needed in the drawing without changing the spreadsheet...
Message 8 of 26
yoann.fusco
in reply to: NigelHay
No, we are also using M8 x 0.5 where the nominal hole diameter is around 7.5mm...
Message 9 of 26
yoann.fusco
in reply to: mcgyvr
The diameter 7mm is the one used from the manufacturer and this diameter is also functional for us in term of internal volume. That is the reason why I need to represent it on my model.
The solution of making a 7mm hole and then apply a thread on it also works indeed, I was just wondering if there were a "more straight forward" solution.
Thank you all for your help!
Yoann
Message 10 of 26
mcgyvr
Yoann
Did you read what I wrote?
Does that work for you? (It should)
I'll post it again..
Go to "Tools..application options.....document settings...... modeling tab
It can't get any "more straight forward" than that..
That setting is there specifically so that those that want threaded holes (placed using the hole tool) can change the "as modeled" size to be either minor or major or tapped drill,etc...
Message 11 of 26
RobertKarlsen
in reply to: mcgyvr
Hello!
I have the same problem, and when i ....
"Go to "Tools..application options.....document settings...... modeling tab
Change it to "tap drill" and you will get your 7mm hole.."
But this will only affect the part file that i have open, and not for the future parts. Is there a solution now for this problem? i have 2019 version.
Robert
Message 12 of 26
Hi Robert,
You will need to change the Document setting in the template file also. I assume you use the system default templates. Go to C:\Users\Public\Public Documents\Autodesk\Autodesk Inventor 2019\Templates\. Open Standard.ipt and make the change there and save it.
Many thanks!
Software Test Engineer
Message 13 of 26
There was the answer!
Thanks 🙂
Message 14 of 26
Ced495
in reply to: mcgyvr
Yoann
Hi, I have the need to display threaded holes as the tap diameter not minor diameter. I tried the mentioned solution and I get a message "Drawind Manager thread representations are generated correctly only when Tapped Hole Diameter is set to "Minor".", this message appears to any option other than "Minor". So it seems these options are there for no reason and don't work. I also checked the diameters and they were still minor diameter instead of the tap diameter. Inventor version: Build: 330, Release: 2019.4. Any ideas?
Message 15 of 26
SBix26
in reply to: Ced495
The message you receive is merely an alert to let you know that drawings made from this model will not show the hole correctly if it's not set to Minor.  If you're OK with that, then change it to Tap Drill.
In other words, a drawing of a model with tapped holes shows the hole size specified in the model, and this is typically the minor diameter because that represents reality as nearly as possible.  But if you need your holes to show the tap drill size, then that's what your drawings will show also.  I don't think anyone will notice, because hole annotations come from the hole data, not from the geometric representations; and because the tap diameter is typically very close to the minor diameter.
However, if your threaded hole is a tapered pipe tap, then it does make a noticeable difference.  Tap drill and minor diameter are not only different in size, but also in angle.  Tap Drill representation is cylindrical, Minor Diameter shows the conical profile, as it should.
Sam B
Inventor Pro 2020.0.1 | Windows 7 SP1
LinkedIn
Message 16 of 26
kstate92
in reply to: SBix26
Sam B
LinkedIn
I have to disagree with this opinion and the hole notes being based on minor instead of tap drill diameters.  Mainly, due to the - realistic - requirement of Thread Depth.  Having the bottom part of a partially-tapped blind hole (the only realistic tapped blind hole type) set at the minor diameter is not only wrong, but just (IMHO) lazy programming, both of the feature AND the hole note.
And MAN do I still hate this forums' posting software.
KState92
Inventor Professional 2020
AutoCAD Mechanical 2022.0.1
Windows 10 Pro 64 bit - 1903
Core i7-8700 32 GB Ram
Quadro P2000
Message 17 of 26
SBix26
in reply to: kstate92
Sam B
LinkedIn
It may not be realistic, but it is normal drafting practice.   In addition, hole annotations, by default, do not reference the minor diameter nor the tap drill diameter; again, normal drafting practice assuming that the fabricator knows what they're doing in selecting the tap drill.  If you need tap drill to be specified, then dimension styles can be modified to include that information.
Sam B
LinkedIn
Message 18 of 26
Ced495
in reply to: SBix26
Thank you for the explanation. If the message is just informative let it be. But, as I understand, if I switch to "Tap Drill" and click "Yes" on the message, I should get a change in the measured dimension of the hole. I do not see any change no matter what I pick in the drop-down. I set the Tapped hole diameter to Tap Drill, I create an M6 threaded hole, I put the model onto a drawing, the full circle gives a diameter of 5 (I expect that to be 6), the thread line around the hole (which isn't a full circle) gives a radius of 3 (which matches with the M6) and the "Hole and Thread note" tool shows the appropriate information. Now the issue is when I put this in a DXF file I get a 5mm circle but I wish it to be 6 in my case, I hoped that the tapped hole diameter setting would achieve that but it does not change anything. What is the setting supposed to do?
Message 19 of 26
kstate92
in reply to: SBix26
Sam B
LinkedIn
Sam B
LinkedIn
We've always specified tap drill sizes in our notes.  Probably much less so in Metric, but some Imperial sizes have a few choices in drill size (again: thread engagement depth), that if left to some machinist's desire for speed and tap life, could result in threads a bit closer to class 1B than 2B.
It's just measuring the model or drawing after the fact and ending up with hole diameters (below the end of the thread) that gives pause as to why the odd-ball measurement result.  Oh, I just remembered: the MAJOR thread diameters aren't nominal either.
I guess I'm being way too old school, wanting a 3D program to make tapped holes like on a drafting board (nominal hole diameters with nominal major thread diameters).  Get off my lawn, I guess.
KState92
Quadro P2000
Message 20 of 26
SBix26
in reply to: Ced495
Now I'm confused about what you want.  You say you want to see the tap drill diameter, which is 5mm for an M6 thread; but when you get this in a DXF file you want it to be 6mm?  That's the major diameter, which is incorrect and useless, isn't it?
Here's what I get with an M6 blind threaded hole, first with the minor thread diameter, and second with the tap drill diameter:
Minor thread diameterMinor thread diameterTap drill diameterTap drill diameter
I can see where using the tap drill diameter might be preferred (I was incorrectly thinking that tap drill would be slightly smaller than minor dia -- doh!), and there's no reason not to, except for tapered threads.
Sam B
LinkedIn
