ILOGIC CUSTOM ¨PARAMETER in CUSTOM PROPERTY
stefan.godfroid
stefan.godfroid
I have a custom parameter "TEKENCODE_INPUT" which can be edited with Multi Value list.  (see photo)
Now i want this parameter filled in a custom property.
I do this with a Ilogic Rule
SyntaxEditor Code Snippet
Dim TEKENINGCODE, TEKENCODE_INPUT As String
Dim TC_input, TC_output As String
TEKENCODE_INPUT = TC_input
Select Case TC_input
Case S
    TC_output = "S"
Case K
    TC_output = "K"
Case Else
     TC_output = "X"
End Select
iProperties.Value("custom", "TEKENINGCODE") = TC_output
But whatever i choose, the custom property "TEKENINGCODE" has alwayes the value "S".
What do i wrong?
petestrycharske
Stefan,
Good morning!  I believe all you have to do is set the custom iProperty equal to the value of your parameter.  Please let me know if the information below gets things working for you.  If you have any questions, please do not hesitate to contact me.  Hope this helps and have a most blessed day!
Peace,
Pete
iProperties.Value("Custom", "TEKENINGCODE") = TEKENCODE_INPUT 'The name of the parameter
iLogicVb.UpdateWhenDone = True
Just a guy on a couch...
Please give a kudos if helpful and mark as a solution if somehow I got it right.
Curtis_Waguespack
Hi stefan.godfroid,
Since you are wanting to set the iproperty to be "X" when the parameter is anything else than S or K in the simple example, you would use something like this:
'select the case for TEKENCODE_INPUT
Select Case TEKENCODE_INPUT
Case "S"
    'more code for other stuff here
	'when Case is S
	TC_output = TEKENCODE_INPUT
Case "K"
	'when Case is K
Case Else
	'when Case is not S or K
	TC_output = "X"
End Select
'set the custom iproperty to match the parameter
iProperties.Value("Custom", "TEKENINGCODE") = TC_output
If you wanted it the iProperty to always match the parameter value you would use what petestrycharske posted.
Also just as a tip, you can search and ask programming questions of this type on the Inventor Customization forum too:
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
I hope this helps.
Curtis
