Inventor Forum
No 3d Sketch Inside Assembly?
8 REPLIES 8
Message 1 of 9
e_frissell
526 Views, 8 Replies
Trying the frame generator for the first time and can't get "Select Line" to work.  Tried making an extruded box and selecting the edges and that didn't work, tried again with 2x 2D sketches and a 3D sketch connecting them but still no dice.  Verified that I can insert items from content center.
What am I / this program doing wrong?
Edit: title's not relevant to the post, dunno how to delete posts.  The first issue was the 3D sketch dialog took about a minute to load and was greyed out so I made the post assuming 3D sketches in a part where somehow unavailable when editing in context of the assembly.  The above is now the next headache I'm facing
8 REPLIES 8
Message 2 of 9
JDMather
in reply to: e_frissell
@e_frissell
Zip and Attach your assembly here.
Message 3 of 9
e_frissell
in reply to: JDMather
Here's the zipped file
Message 4 of 9
JDMather
@e_frissell
What do you see after selecting a line to place the frame member?
Message 5 of 9
e_frissell
Here's what pops up.  I can click on the lines but it never actually selects the line and places a member
Message 6 of 9
johnsonshiue
Hi! Indeed, Inventor does not support 3D sketch at the assembly level. You will need to create the skeletal part and place it in the target assembly. Then start Frame Gen Insert command -> pick the 3D sketch lines from the part.
Many thanks!
Software Test Engineer
Message 7 of 9
e_frissell
in reply to: johnsonshiue
Weird, it actually loaded for me but took a minute or two
Any thoughts on what could be causing my frame generator to not allow line selection?
Message 8 of 9
Frederick_Law
Your dialog missing Material:
Message 9 of 9
Frederick_Law
Check your Project's Appearance and Material Library:
