Hello community,
Is it possible there is no parameter to control distance between parts in nesting?
Solved by CCarreiras. Go to Solution.
Hi!
The distance between parts is defined in the material.
Case 1- Before creating the Nest, you can set the distance between parts here:
Case 2 - After creating the nest, you can edit it, and override the material´s distance between parts:
