Nesting - etch part number and sheet name
Stefan_PPI
Stefan_PPI
hi everyone,
we looking for an easy way to etch on every part, sheet name and part number (see attached picture).
So that we can match each cut out part to the exact sheet!
Thank you in advance
P.s.: We are are using Product Design Suite 2022.
mrB_Young
I don't have the final solution, but I think iLogic can be used to feed text into sketch which could then be used for etching.
Inventor user since 2009
Vault user since 2010
IgorMir
One way of getting it done is to place a text on the Flat Pattern itself. When creating a Flat Pattern DXF file - the text will be there on its own layer. That layer has to be marked as an etching one in the Laser cutting machine's software.
In later releases of Inventor (beyond IV2020 one) - there is a dedicated function available for this very task. But for earlier releases - a simple sketch with the text should work just fine.
Cheers,
Igor.
Web: www.meqc.com.au
johnsonshiue
Hi! This can be done on Inventor 2023 using Mark feature.
Many thanks!
Software Test Engineer
