I would like to take a solid and place x (variable) number of work planes / sketches on y (variable) interval along one of its dimensions. Each sketch would have an outline graphic created by the "Project Cut Edges" command on it. Though use of a Form I would be able to change the x and y values. I can use the Rectangular Pattern command to array the work plane but not the sketch. Any way to automate this short of writing code ?
Thanks in advance,
Nick
Show what you have got so far, your description is hard to understand.
IMHO not possible without of programming.
Jürgen Palme
I too am a bit confused as to what you want..
Can you post a part file where you have started this manually?
Sometimes I find its also best to post specifics about the problem you are actually trying to solve/task you are attempting to achieve and not just what you think the solution should be. Like what is all of these workplanes/sketches for.. what are you hoping to achieve with them once created.
Hello -
Thanks for responding. Hopefully this will clear up my intent.
Say I have a lofted shape and I need a series of cross sections illustrating the limits of the shape. I have attached a simple model with three sections.
What I would like to do is to via a form, input the number of sections I would like and the distance between them and have Inventor create that number of workplanes\sketches for me. For example I may want 20 sections at height/(20 +1) interval.
Thanks;
Nick
Are they all the same spacing?
You could just do that with a pattern.
From what I can see a pattern will only allow me to replicate the work plane - not the sketch that is on it. I could use the pattern command as desired and have all the work planes I need but would then need to manually create the sketch on each. Hoping to do this automatically.
Nick
The purpose of the individual work planes/sketches is to have a cross section of the body at each location that will ultimately be exported to another application. If you move the work plane in the sample drawing I supplied, the sketch updates the cross-section automatically.
Currently the process is to manually create each work plane, manually create a sketch on each work plane, and then manually run the Project Cut Edges on each sketch. I want to automate that process. I may have 500 cross sections to create, I don't want to do that manually.
Well isn't that interesting...graphics glitch what.... NFT available soon 😁
Sorry, you explained all that in your first post, I was getting confused with another one I'd read about lofting.
Without using iLogic (and I don't know if you can) there's no way to do this that I can think of.
I pretty much have arrived at the same conclusion. Thanks to everyone who has looked at and considered my question.
Nick
@nick.seman wrote:
... that will ultimately be exported to another application.
Section Analysis is so close...
to what you are after.
J.D. - you are not kidding that is so close . . .
If I could only take those outside boundary lines and change them into 3D sketches I would be set.
Thanks;
Nick
Hi Nick,
I believe there are ways to do this. To create uneven spaced workplanes, you can create a 2D/3D sketch with uneven spaced points. Then populate the workplane at the points using Sketch Driven Pattern.
Regarding Project Cut Edges, you can create a 3D Sketch and then use Intersection Curve command to create such curves between the workplanes and the Loft body.
Many thanks!
@nick.seman wrote:
... and change them into 3D sketches
Why 3D sketches?
As far as I understand you're looking for 2D sketches on each of the workplanes (?).
Jürgen Palme
