My PC has crashed and I have bought new, I need to use Inventor version 2019 to run Ansys. Can you send me a new license for 2019?
Solved by mcgyvr. Go to Solution.
Solved by Cadmanto. Go to Solution.
This is a forum to help you solve issues with Inventor. Not a place where you can obtain a license for Inventor.
My suggestion would be to either contact your local VAR or go to the Autodesk website and down load the 30 day trial version.
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2020
Inventor Pro 2020
@ingb This is a user to user forum and not a dedicated Autodesk staff support forum.. We are just users of the software like you are.
If your computer crashed you should be able to still log into your account at https://manage.autodesk.com/home/ and retrieve your license there. You do not need a new license.
If you are still having a problem you can contact Autodesk through this form
https://knowledge.autodesk.com/contact-support/installation-activation
