Inventor Forum
Need help to dra triangle with round corners
3 REPLIES 3
steenH797P
253 Views, 3 Replies
Can anyone in the group help me to draw this sketch ?
diameter of all 3 part is 120 cm
3 REPLIES 3
WHolzwarth
in reply to: steenH797P
Technically shapes like this are known as P3G profiles (DIN 32711).
I've done it with an equation curve. Similar shapes can be designed by changing parameter e (actually 0,63 with R=10)
Walter Holzwarth
JDMather
in reply to: WHolzwarth
@WHolzwarth
I haven't looked at the standard you referenced - but aren't there an infinite number of solutions with only the given information?
WHolzwarth
in reply to: JDMather
You're right, Jeffrey.
In my Equation curve, Parameter e shows similar behavior.
Walter Holzwarth
