Can anyone in the group help me to draw this sketch ?
diameter of all 3 part is 120 cm
I use Inventor 2019
Solved by JDMather. Go to Solution.
Technically shapes like this are known as P3G profiles (DIN 32711).
I've done it with an equation curve. Similar shapes can be designed by changing parameter e (actually 0,63 with R=10)
Walter Holzwarth
I haven't looked at the standard you referenced - but aren't there an infinite number of solutions with only the given information?
You're right, Jeffrey.
In my Equation curve, Parameter e shows similar behavior.
Walter Holzwarth
