Inventor Forum
Need help installing logo onto surface
5 REPLIES 5
508 Views, 5 Replies
I need help putting picture or logo it to a text box and emboss it onto surface
5 REPLIES 5
mpatchus
If a decal won't do and the logo actually needs to be embossed or engraved, I simply create outlines of the logo shapes in a sketch using the image as a guide.
Once it has been created as a sketch, it can easily be embossed onto a surface.
To reuse this logo sketch, simply create a iFeature from the sketch.
I've attached the part for you to look at.
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
JDMather
What problem are you experiencing?
Attach your ipt file attempt here.
Thank you. I got it. Now I have to find a way to apply it to an assemby?
in reply to: JDMather
Do you know a way to apply it into a assembly?
mcgyvr
First.. Is the label itself a stocking part for you? ie it has a part number and must be included in the BOM.
if so...
I would make a part with just an extruded surface surface that matches the radius of the round bar and is the same size as the label. Then apply the decal to that surface (wrap to face option I believe) then you save that as the part number. Then you can simply drop that into your assembly and constrain as necessary.
