we went through a painstaking task of trying to do this when we working on the Hudson Yards Vessel openings. The manufacturer would only provide us a section in Navisworks which, to be honest, was almost impossible to work with. Here is what we did-
exported the model from Navisworks as FBX
imported FBX into Rhino
Created faces to each face we needed using the geom from the imported file
exported from Rhino as a surface model
imported the Rhino model into Inventor as surfaces
applied a thicken to each face we needed
even with the work, the geom comes with tones of rogue lines and split faces. its a difficult timely process
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
