Using Inventor Content Center to design weldment made of Berkely SF Ltd.
Hello. Do somebody have an idea how to use ICC to fit in BSF Hygienic Fittings?
I would have really appreciated even any similar standard to BS4825 PT2 Short accessible in ICC.
Thank you
CGBenner
@Anonymous
Hi!  I can tell you from experience that these do not exist in the CC out of the box.  In my last position, I had the same issue.  I was able to either model or download models of all of the fittings I needed, and then author and publish them to a custom CC library.  The good news is that, if you do need to create the models, these are not really tough models as far as geometry.... it's just a lot of work.  Some suppliers will provide CAD models that you can download, so I would check that first.  For Tri Clamp connectors, you can get models of those from McMaster Carr's website... they would probably be close enough to the correct geometry that you could use them.... and don't forget your gaskets!
Good luck!
Chris Benner
Thank you for your help. Appreciated!
Have a nice day
