Multiple selection to add a iMate
Reinier
Reinier
Dear All,
I have a Part with multiple Workpoints. When I create a iMate I need to make a selection. Is it possible to select multiple Workpoints? Because the will all have the same iMate. I can make them all individual, but that takes to much time, is there an easier way?
Reinier
johnsonshiue
Hi Reinier,
Unforunately, I am not aware of a way to do that. Each iMate definition is similar to assembly relationship (constraint). If you cannot multi-select geometry to create an assembly constraint, it will not work for iMate either. It is a good idea though. Please feel free to submit it to Inventor Ideas forum.
Many thanks!
Software Test Engineer
kelly.young
Autodesk Support
Autodesk Support
@Reinier Here is a similar idea for what you're looking for:
iMates impovements request
Please select the Accept as Solution button if a post solves your issue or answers your question.
