Dear All,
I have a Part with multiple Workpoints. When I create a iMate I need to make a selection. Is it possible to select multiple Workpoints? Because the will all have the same iMate. I can make them all individual, but that takes to much time, is there an easier way?
Reinier
Solved by kelly.young. Go to Solution.
Solved by johnsonshiue. Go to Solution.
Hi Reinier,
Unforunately, I am not aware of a way to do that. Each iMate definition is similar to assembly relationship (constraint). If you cannot multi-select geometry to create an assembly constraint, it will not work for iMate either. It is a good idea though. Please feel free to submit it to Inventor Ideas forum.
Many thanks!
@Reinier Here is a similar idea for what you're looking for:
Please select the Accept as Solution button if a post solves your issue or answers your question.
* Ideas * Help * AKN * Updates * Pack & Go * Reset Utility * Repair Install * Customization * iLogic Examples * Autodesk University *
