Inventor 2016 memory accumulation
J-Camper
J-Camper
I have noticed today, after months of no issue, that my Inventor 2016 is not letting go of memory when files are closed.  This is the first time It has done this since I started working at my new job (6+ months), and I can't remember changing any settings recently.
I have worked longer days, with larger files, and been able to open, close, and flow through files with no problems.  Today I noticed my RAM build from 6.5GB to 11GB while working in an increasingly sluggish Inventor.  I restarted the program and it has risen again from 6.5-11GB just from opening and closing inventor files.
Has anybody experienced a similar issue?  Is the some option that was changed which keeps Inventor from releasing memory of previously opened files?
The rest of my computer functions normally, AutoCAD, internet, email, ect.  Inventor is the only thing slowing down.
Replies (7)
johnsonshiue
Hi! A few things to check. Is there only one Inventor.exe running? Are you accessing files from network drive? Did you clean up %temp%?
Many thanks!
Software Test Engineer
Xun.Zhang
Hi @J-Camper,
Are you working on a large assembly? How many individual components contains in such assembly?
What's your hardware configuration such as CPU, RAM, Graphic card, etc?
Have you tried the Express mode? It might help you a little bit. Refer more -
http://help.autodesk.com/view/INVNTOR/2016/ENU/?guid=GUID-34C9AE4C-EDA7-4E46-AD51-3383A67FF1B9
Hope it helps a little bit.
Xun
J-Camper
Yes I only have one instance of inventor.exe running.
No I do not work off a network drive.  I get files from the network through vault and put them on my hard drive to work.
I'm not sure where to look for the %Temp%, can you expand on this?
J-Camper
The assemblies range upwards from 3MB-10MB with anywhere from 30-250 components, and drawings as big as 50MB
I don't believe this has anything to do with my system performance because I have used the same PC without issue for 8 months, but I have an i7-6700 CPU @ 3.4GHz, 16GB RAM, and I'm not sure of my graphics card (it was built before I started working) but it is not stock.
I have never heard of express mode, but I will look into whether or not it will work for me.
johnsonshiue
Hi! Could you provide your hardware profile? Start Inventor and open a part. Go to Tools -> Application Options -> Hardware -> Diagnostics -> paste it to a text file and send it to me directly (johnson.shiue@autodesk.com).
It is possible the machine is not using the dedicated graphics card. Instead, it is using an on-board graphics card not suitable for running CAD application.
Many thanks!
J-Camper
RESULTS:
This Direct3D graphics driver is Microsoft WHQL certified
Graphics Hardware Description:
Advanced Micro Devices, Inc. AMD Radeon Graphics Processor (0x6610)
AIRViz Device Manager \ VirtualDeviceDx11
Feature Level 5_0
Performance Mode
Hardware Renderer
Graphics driver file aticfx64.dll,aticfx64.dll,aticfx64.dll,aticfx32,aticfx32,aticfx32,atiumd64.dll,atidxx64.dll,atidxx64.dll,atiumdag,atidxx32,atidxx32,atiumdva,atiumd6a.cap,atitmm64.dll is version 21.19.144.32768
The display is using 32-bit color
Inventor Version:
Build: 236, Release: 2016.2.6 - Date: Tue 11/07/2017
64-Bit Edition - 8192.00 GB
Loaded Inventor Add-Ins:
Assembly Bonus Tools
iCopy
Electrical Catalog Browser
System Information:
Operating System: 64-bit Microsoft Windows 7 Professional (Build 7601) Service Pack 1
Language: English
System Manufacturer: Dell Inc.
System Model: OptiPlex 7040
BIOS: BIOS Date: 02/06/17 01:23:09 Ver: 1.5.9
Processor: Intel(R) Core(TM) i7-6700 CPU @ 3.40GHz (1 processor, 4 physical cores, 8 logical cores)
System Memory: 15.907 GB RAM
Graphics Device Information:
Renderer: HAL
Manufacturer: Advanced Micro Devices, Inc.
Chip Type: AMD Radeon Graphics Processor (0x6610)
DAC Type: Internal DAC(400MHz)
Graphics HW Memory: 3.980 GB
Display Mode: 1920 x 1080 (32 bit) (59 Hz)
Graphics driver file: aticfx64.dll,aticfx64.dll,aticfx64.dll,aticfx32,aticfx32,aticfx32,atiumd64.dll,atidxx64.dll,atidxx64.dll,atiumdag,atidxx32,atidxx32,atiumdva,atiumd6a.cap,atitmm64.dll
Driver file version: 21.19.144.32768
Driver Date: 25 October 2016 0:00:00 UTC (Coordinated Universal Time)
Direct3D Graphics Device Information:
Adapter Description: AMD Radeon(TM) R7 350X
Vendor ID string: 0x00001002
Device ID string: 0x00006610
VendorID: 1002
DeviceID: 6610
SubSystemID: 811028
Revision: 81
Direct3D 10 / DXGI System Information:
Dedicated Video Memory: 3.980 GB
Dedicated System Memory: 0 MB
Shared System Memory: 3.750 GB
DxDiag System Information:
Operating System: Windows 7 Professional 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_ldr.170913-0600)
Language: English (Regional Setting: English)
Processor: Intel(R) Core(TM) i7-6700 CPU @ 3.40GHz (8 CPUs), ~3.4GHz
System Memory: 16384MB RAM
Page File: 7942MB used, 24632MB available
DirectX Version: DirectX 11
DxDiag Version: 6.01.7601.17514
DxDiag Graphics Device Information:
DirectX Version: 10.0
DDI Version: 11
DDI Version Number: b
DxDiag WHQL Level: 0
Driver Signed Valid: True
Driver Signed: True
Revision:
Graphics HW Memory: 3819 MB
Display Mode: 1920 x 1080 (32 bit) (59Hz)
Driver file version: 21.19.0128.0004
Driver Date: 10/26/2016 11:25:16
WHQL Level: 1
Inventor Options Information:
Options = 0x00000000
Warning Options = 0x00000000
Graphics driver log information:
johnsonshiue
Hi! Many thanks for sharing the hardware profile! The only thing I can tell is that the graphics driver seems to be old. Please go to AMD site and upgrade to the latest compatible driver. After that, please report the findings.
Thanks again!
