Multibody parts
Multibody parts
chachaman
Message 1 of 12
Multibody parts
chachaman
Is there a way to callout the name of a body of a multibody part in the IDW drawings ?
For example, is there a way  for teh ballon  callouts to identify the body ? Can the text Annotations be made to point to the body ?
Thx
Replies (11)
Message 2 of 12
pcrawley
No... and yes.
Balloon looks for Part properties, so don't waste too much effort making them look for anything else.  Leaders are generally the same - so neither option does what you need.
However, this old post shows how you can do what you ask: Solved: Re: Reference solid body name in balloon text? - Autodesk Community - Inventor
Since the post is approaching the Autodesk 10-year cull policy, here (for the next 10 years hopefully) is code.
Note - you need to place balloons on the drawing of the multibody (they'll all show the same value).  Next select the balloons one at a time and run the rule.  The balloon text should update to reflect the body name.
Sub Main()
	Dim oSS As SelectSet
	oSS = ThisApplication.ActiveDocument.SelectSet
	oSS.Item(1).BalloonValueSets.Item(1).OverrideValue = GetSolidName(oSS.Item(1))
End Sub
Function GetSolidName(oBalloon As Balloon) As String
	Dim oLeader As Leader
	oLeader = oBalloon.Leader
	Dim oNode As LeaderNode
	Dim oModelGeom
	For Each oNode In oLeader.AllNodes
		If Not (oNode.AttachedEntity Is Nothing)
			oModelGeom = oNode.AttachedEntity.Geometry.ModelGeometry
			Exit For
		End If
	Next
	If oModelGeom.Type = ObjectTypeEnum.kEdgeObject
		oSurfaceBody = oModelGeom.Faces.Item(1).SurfaceBody
	Else
		oSurfaceBody = oModelGeom.SurfaceBody
	End If
	GetSolidName = oSurfaceBody.Name
End Function
Peter
Message 3 of 12
chachaman
Hello PCCrawley,
It's very kind of you to dig this up and present it so helpfully !   This really helped me !
All my gratitude and kindest regards !  HNY too !
Thanks again !
Message 4 of 12
kacper.suchomski
I will add that in the case of a larger number of shapes, it is worth creating a form to have the command close to the cursor and not have to travel around the screen every time.
(view in My Videos)
Kacper Suchomski
Message 5 of 12
chachaman
That's a fan tastic tip ! Thx !!
Message 6 of 12
chachaman
Can you tell me what seeting in the forms dialog allows you to switch focus between the form and  the ballon ? Presently, when the form is displayed, I cannot select the balloon .....
Thx
Message 7 of 12
kacper.suchomski
Please change modal setting.
https://help.autodesk.com/view/INVNTOR/2025/ENU/?guid=GUID-40B1D589-4D0C-4B46-AB52-896F0C7D78F4
Kacper Suchomski
Message 8 of 12
chachaman
Thanks a million Kacper ! 😀
Message 9 of 12
pcrawley
Ok, if it's a competition for making it easier... 😉
Modify the code as follows.  Now you can select multiple balloons - then run the code - and they all change 🙂
Sub Main()
	Dim ObjB(oSS.Count) As Balloon
	NB = oSS.Count
	For i = 1 To oSS.Count
		ObjB(i)=oSS.Item(i)
		Logger.Debug(GetSolidName(oSS.Item(i)))
	Next
	For i = 1 To NB
		ObjB(i).BalloonValueSets.Item(1).OverrideValue = GetSolidName(ObjB(i))
	Next
End Sub
	Dim oModelGeom
			Exit For
		End If
	Next
	Else
	End If
End Function
Peter
Message 10 of 12
kacper.suchomski
I love this kind of competition  👏👏🙌
Kacper Suchomski
Message 11 of 12
chachaman
Awesome !
How do I buy you a coffee !!!
Message 12 of 12
pcrawley
You just did 🙂
I had to do this myself once and thought about coding it - but I was too lazy and just over-rode the text manually.  Today I was thrown a project where everything has been modelled as a single multi-body part - so this routine has been sooooooooooooooooooooo helpful - so thanks for making me less lazy!
Seriously though, it's a great question and probably should be a "standard feature" - like having iProperties on individual solid bodies and letting the drawing tools recognise those body-properties.
Peter
