Sweep not working
Sweep not working
onlrendelek
Sweep not working
onlrendelek
Hello!
I am trying to create a sword blade.
I made the outer shape in sketch, then extruded it. Then I want to make the edge (blunt edge) with sweep (in cut mode)
For the profile I want to use skecth4. For the path I want to use sketch5. The orientation would be: follow the path.
Why it does not working? I know there can be other solutions, but I want to use the sweep, and understand why it's not working.
Thank you in advance!
Erik
Sweep cause a self intersection.
kacper.suchomski
Hi
On the video you can see how the Sweep geometry solid behaves around the apex.
That's why you get a message about self-intersecting geometry (it's worth reading the messages - they often describe the problem in detail).
You need to change the modeling method or add an internal path to guide the profile.
(view in My Videos)
Kacper Suchomski
onlrendelek
Thank you!
